nexus
I going to be running two drives around water(Fluid test lab). The drives are for a 15 Hp pump and a 3 Hp pump. I will have water flowing over top of the location were the drives will be located. What type of enclosure do I need to keep the water and heat from the drives out. I need sufficient air movement to keep the drive from overheating. what do you recommend?
