Codesys :How do i read all lines of text from a text file?
EnterDownload
May 2015
NY
Hello
I am using codesys v3.5.
I am using the CAA File library to read/write lines of text from a file stored on my Festo PLC.
I have found out how to read 1 line of text from my text file.
But how do I read the next set of lines within the text file separately until the end of file is reached?
Example:
Read line 1
Read line 2
Read line 3
Read line 4
End of File
I know I would normally put the code in a "Repeat" loop until end of file ...but what should the code look like to read all lines until all lines have been read or End of File?
thanks
Jay
Maybe I need more explanation?
Im trying to read all lines from a text file stored on my PLC, 1 by 1
Something like the code below. The problem is this code below always reads the same 1st line...how do I change to the code to read the next lines in my file?..e.g. line 2, line 3, ect
Repeat
FileRead(xExecute:= TRUE, hFile:= hfile, pBuffer:= ADR(sReadLine), szBuffer:= SIZEOF(sReadLine));
Until xEOF
End_Repeat
Hello, I´m using Codesys 2.3 and trying to access Wago I/O modules 750-430 and 750-530 by WORD variable (or maybe an array), unsure if it´s...
1,840
Read Tag from Rockwell PLC from Codesys 3.5? Rockwell PLCs would be 5370s, 5380s, 5570s, and 5580s etc. It seems everyone's EtherNet/IP...
73
21,616
Hello to all, can you please provide an example of obtaining a current working directory as a string in CodeSys? For example, during starting the...
223
Hello to all, I'm just starting with using CodeSys. Immediately, I have noticed that Codesys doesn't use data blocks like for example S7 does...
221
Hello, I am using a Hitachi Micro EHV+ for a small project, and I wanted to have a Web visu, done with Codesys V3.5 SP13 Patch 2. I test the...
449
