PhysicalAxisFault at Kinetix 6000
mike3475
Feb 2013
brooklyn ,NY
334
Hi,Guys:
we got issue with Kinetix6000 servo drive with E06 (HardOverTravel Fault),
I saw "AS_Axis06.PhysicalAxisFault" showing 1 at monitor tag of Studio 5000 when Kinetix6000 servo drive shuts off with E06.
should I change the physical travel limits for this servo drive to make its travel range a little bigger?
thanks!
You should not cross the hard limit unless something has gone horribly wrong, the axis travel is badly designed, or the sensors are in the wrong position.
Hi All, I have a 2097-V31PR0-LM Kinetix 350 and a TLY-A110T-Hxx2 servo. It is a new setup and I've commissioned the drive: Scaling, hookup tests...
21,385
Hi guys, I have the first Kinetix 5100 in my facilities. I already configure the movement in Speed Mode, I am sending the Analog signal from my...
51
Hi all, I am upgrading a couple of 2094-BC01-M01 servos with 2198-H015-ERS. The original code uses MSG instructions to control (release, engage...
83
Hello all I was trying to autotune a Kinetix 5100, I got an encoder fault and it says to check the wiring. I remove the 24 volts from drive to...
53
Hello everybody, I have Kinetix 5500 (2198-H040-ERS). I'm having issue with this drive. (I believe it's the drive/Kinetix and need confirmation)...
62
