PhysicalAxisFault at Kinetix 6000
mike3475
Feb 2013
brooklyn ,NY
334
Hi,Guys:
we got issue with Kinetix6000 servo drive with E06 (HardOverTravel Fault),
I saw "AS_Axis06.PhysicalAxisFault" showing 1 at monitor tag of Studio 5000 when Kinetix6000 servo drive shuts off with E06.
should I change the physical travel limits for this servo drive to make its travel range a little bigger?
thanks!
You should not cross the hard limit unless something has gone horribly wrong, the axis travel is badly designed, or the sensors are in the wrong position.
Hi All, I have a 2097-V31PR0-LM Kinetix 350 and a TLY-A110T-Hxx2 servo. It is a new setup and I've commissioned the drive: Scaling, hookup tests...
21,174
Kindly, we have the following configuration fault on a Kinetix 5700 axis. It only appears when we go online on the Plc. We are just starting the...
99
Dear team, We are constantly facing M07 incremental loss on one of our kinetix 6500 safe torque. We have changed Servo motor (MPL-B4530K-MJ72AA)...
112
Have a system that has been running for over a year and all of a sudden getting a ExcessiveVelocityFault on one of the drives when the MSO command...
150
Hello PLCS.Net Forum, First time posting. Let's assume I am a novice. BASIC PROBLEM: My servo/linear piston is no longer zeroed to the...
227
