Pausing a timer in Crimson 3.0 software
Paulx_42
Dec 2017
washington
Hello,
I am new to the forum. I have been using the Redlion Crimson 3.0 software for about 3 years. I have never had any luck pausing a timer. I have incremented and decremented timers but can't figure out how to pause one. I have a temperature that i am watching and if it drops by 2 degrees I want the timer to stop where it is until the temperature gets back up to where it should be then start the timer again. I have been working on taking a snap shot of the time and saving it, then reload that value back into the timer but it seems pretty cumbersome. Has anyone ever tried to pause a timer?
Are you doing all this logic in a Red Lion? This is really a job for a retentive timer in a PLC. Tell us more about the specific hardware you are using.
I agree that retentive timers in a PLC would be great. That is not an option at the moment. I am using a Graphite HMI, a Thermocouple input card, a discrete in/out card and 1 universal input card for an oven temperature. I am in the process or checking all the timers that come as part of the Crimson Control module that allow Ladder Logic, Function block and structured text program languages to see if they have anything like a retentive timer.
Ok, FYI, I have found a timer similar to a retentive timer in the Crimson Control module functions. It is called a TMD. It is a countdown timer that stops when the input goes false. It has a reset input to put the counter back when it has finished.
There was no great way to describe the behavior this temperature input is demonstrating, so I attached a video. It ramps, then hesitates, then...
17
5,277
At issue: I'm trying to get multiple trends to pause (and also hopefully navigate) at the same time from one set of buttons on a display. This is...
1,243
Hello, To make it short, the current system setup is a compact logic with a high speed counter 1769-HSC input module reading pulses from a flow...
2,035
1,102
Currently I am using a bunch of TON's and TOF's to start up and turn off a motor sequence. I created a sub routine for the manual sequence and I...
4,732
