Pausing counter value
wanher3
Feb 2018
USA
65
Hello,
To make it short, the current system setup is a compact logic with a high speed counter 1769-HSC input module reading pulses from a flow meter. I'm currently trying to, based on an event, paused to pulse count on input channel A0, and then resume the counting operation once that event is gone. Has anyone done such thing ? I read the manual for that module but it wasn't clear which configuration bit can be used to do that.
Hello, To make it short, the current system setup is a compact logic with a high speed counter 1769-HSC input module reading pulses from a flow...
1,997
There was no great way to describe the behavior this temperature input is demonstrating, so I attached a video. It ramps, then hesitates, then...
17
5,257
At issue: I'm trying to get multiple trends to pause (and also hopefully navigate) at the same time from one set of buttons on a display. This is...
1,233
Hello, I am new to the forum. I have been using the Redlion Crimson 3.0 software for about 3 years. I have never had any luck pausing a timer...
1,906
Currently I am using a bunch of TON's and TOF's to start up and turn off a motor sequence. I created a sub routine for the manual sequence and I...
4,711
