Question on AB 1762–IF4 Analog input module saturated
jay mason
Oct 2013
Easton Pa
Trying to figure out why I see 40ma when reading the current inline with the analog card.
I have a load cell with a 4 to 20ma signal and the signal conditioner is set up to split the signal as the force is cycled between compression and tension the zero should be 12.0ma and I read 13 ma at zero and when I press the shunt cal on the signal conditioner I should see 19 ma I get 40ma on the meter and 32768 counts on the plc.
I replaced the 1762–IF4 and I still see the same thing.
Any ideas as to what I am missing?
Thank you
Jay Mason
The IF4 is an input device. It won't generate a current. You have two independent devices that would appear to be indicating your actual current is in excess of 20mA. I would look at your signal conditioner.
Keith
Hey all, Been working on a little project using a Micrologic 1100, Just added this 2-in/2-out analog module (1762-If3Of2)to my project, and a...
2,202
Greetings! In the attached wiring diagram the pairs: DC COM 1, DC COM 2, etc... Are they internally jumpered? So in other words, if I want to...
1,771
Hi All, I have a question about the 1762 if2of2 analog module.When i connect both inputs with voltage option (dip switch on voltage position) i...
2,541
I have never had the pleasure of working with a "Thermistor" until now and have a question. The Thermistor is a 10KOhm 4-20mA 2-wire device and I...
85
Hi All, So I have a main routine with an instruction that's executed by XIC "Run" I have a JSR located on a rung below it. In the logic for that...
179
