Adding a TON with TwinCAT
May 2010
Indianapolis
I just took over aproject and need to add a timer using twincat software, but do not have much experience with it. I know how to map in inputs and outputs, but dont know how to add a timer. need to get equipment back online to night hopefully -- any help is much appreciated.
In the sample project supplied with TwinCat (TwinCat\Samples\FirstSteps) there are examples of the use of TON
I was able to simulate and run TON using Structured Text. I have activated "T.IN", however deactivating "T.IN", I noticed that "T.Q" remains activated. When I set "T.Q:=FALSE", the program shows error message. How can I turn this "T.Q" OFF?
Example program:
dev_down := NOT dev_up;
IF start THEN
t1(IN:=TRUE , PT:=t#1s , Q=>, ET=> );
IF t1.Q THEN
dev_up:=TRUE;
t1.IN:=FALSE;
END_IF
END_IF
Thank you very much,
Andrei K.
You must always make the call of ton. Now if start is not true you wont call the ton.
Code:
IF start THEN
      t1(IN:=TRUE , PT:=t#1s , Q=>, ET=> ); //this one will execute the ton, if start is not true, it wont execute, also when call is made u assign true to in so it will always be true when call is made.
  IF t1.Q THEN
    dev_up:=TRUE;
    [COLOR=Red]t1.IN:=FALSE;[/COLOR]
  END_IF
END_IF
Good day,
Thank you very much. I was able to put up a decent ST program just today and this will be the beginning of more complex programs to make. Here is my improved simple "TON" program:
IF NOT start THEN
t1(IN:=FALSE , PT:= , Q=> , ET=> );
t2(IN:=FALSE , PT:=, Q=> , ET=> );
dev_up:=FALSE;
END_IF
IF start AND NOT t2.IN THEN
t1(IN:=TRUE , PT:=t#1s , Q=>dev_up , ET=> );
END_IF
IF start AND dev_up THEN
t2(IN:=TRUE , PT:=t#1s, Q=> , ET=> );
IF t2.Q THEN
dev_up:=FALSE;
END_IF
END_IF
Code:
IF start THEN
  IF t1.Q THEN
    dev_up:=TRUE;
  END_IF
END_IF
You should call the timer exactly once in one program scan.
Example:
Code:
IF (StartCondition)
    THEN
    t1.in := true;
ELSE
    t1.in := false;
END_IF; //this could also be written "t1.in := StartCondition;"
t1(IN:= , PT:=t#1s , Q=> , ET=> ); //execute timer
IF (t1.q)
    THEN
    //do stuff
END_IF;
Basically, modify input parameters, then execute timer, then read output parameters.
Now that's way much convenient. Thank you very much as my ST programming has really improved in a few day span. Here is my revised program:
t2(IN:= , PT:=t#1s , Q=> , ET=> );
IF NOT start THEN
t1.IN:=0;
t2.IN:=0;
dev_up:=0;
END_IF
t1.IN:=1;
IF t1.Q THEN
dev_up:=1;
END_IF
END_IF
t1.IN:=0;
t2.IN:=1;
IF t2.Q THEN
t2.IN:=0;
dev_up:=0;
END_IF
END_IF
Example:
Code:
IF (StartCondition)
    THEN
    t1.in := true;
ELSE
    t1.in := false;
IF (t1.q)
    THEN
    //do stuff
END_IF;
Hi guys,
I am working on TWINCAT v3 and I am trying to call a TON timer inside a function block.
I observed that even though the values of the variables are passed on to the timer function, the timer does not actually start. I tried implementing the same in the main program which calls the function block and here the TON timer works as expected.
I think there is a difference in the execution of code in the function blocks and the programs. Can you please suggest some solution or show me the right way to approach this problem .
Thanks in advance.
The function block must be active to run a timer (any timer)
the timer (TON) must be declared on top are three ??? fill in a name, and in the declaration of variables (VAR, on top of program)) you will put same name like name:TON;
as this thread is 3 years old, please start new one. put twincat in subject, and i will find you
How can I add the "Go To..." function to the RSLogix 5000's Standard Toolbar?
3,626
Does anyone know the best way to add a horn to a start button that stays on for 10 sec then shuts off and the motor starts.
7,180
Does anyone know the bet way to add a horn to a start button that stays on for 10 sec then shuts off and the motor starts.
3,213
Hi, I need help adding a new interlock switch to an existing circuit. I have never done on the existing circuit. I did set it up on the...
277
Hi all I’m looking at adding a RFID card reader to comfort panel pro , how do you set the rfid up can you connect to existing users and password...
94
