AB Micro800 plug in module wiring confusion
RH68
Jun 2008
Maryland
21
Hello,
I am using a Micro820 PLC for the first time and am confused by how the plug-in modules are supposed to be wired. I am using 2 of the 2080-IQ4OB4 modules that each have 4 inputs and 4 outputs. I need to wire the inputs as sinking and outputs as sourcing.
My confusion is that terminal block Pin A3 and A4 are both labeled COM, but the documentation does not say if one is COM for the inputs and one COM for the outputs. And if so, which is which. There is also a 24V+ pin and a 24V- pin. I assume I need to connect to both of these.
Since I am using sourcing outputs, I think I need to give 24V+ to one of the COM pins. Likewise, since I am using sinking inputs I think I need 0V to one of the COM pins.
Does anyone have experience with these and know how to wire them? The AB manual is here: http://literature.rockwellautomation.com/idc/groups/literature/documents/um/2080-um004_-en-e.pdf
Unfortunately it gives no wiring examples.
Thanks for the help!
Hey, I have one of these brand new Micro800 series of PLCs from Rockwell (a Micro830 to be exact). Our project needed a few more outputs, so I...
3,824
My company built a small test machine using a Micro800 PLC and CCW software. We chose the Micro800 because the machine is very simple. We are...
164
Hi, Is there a way to set the IP of a micro dynamically, based on a variable value.?
169
Anyone use the newer 2080-L50E or L70E with 1734 Point IO yet? I have a customer asking for a setup and I have not found anyone that has done...
388
Is there a way to download the program to a Rockwell Micro810 without using the Rockwell CCW application?
737
