Programming Micro800 Plug-in modules
kexlington
Jan 2008
Gladstone
Hey,
I have one of these brand new Micro800 series of PLCs from Rockwell (a Micro830 to be exact). Our project needed a few more outputs, so I thought I would add a 2080-OW4I 4 relay output module... Easier said than done...
In CCW, when I right click on the picture of the controller to add the module, my plug-in module does not show up in the list (see picture). In fact, only a few out of all of the possible plug in modules show up on the list.
Has anyone else had this problem? I have the latest version of the software. There was a sheet that came with the plug-in module mentioning something about user defined function blocks, but I can't find these on my computer or where to download them!
You probably need a copy of these publications:
http://literature.rockwellautomation.com/intradoc-cgi/nph-idc_cgi.exe
Micro800 Digital Plug-in User Defined Function Blocks
Catalog Numbers 2080-IQ4, 2080-OB4, 2080-OV4, 2080-OW4I, 2080-IQ4OB4, 2080-IQ4OV4
User Defined Function Blocks (UDFB)
In order to use your plug-in, you must first import the following two user defined function blocks to your Connected Components Workbench project.
RA_2080_IQ4x – for catalogs 2080-IQ4, 2080-IQ4OB4, and 2080-IQ4OV4
RA_2080_Ox4 – for catalogs 2080-OB4, 2080-OV4, 2080-OW4I, 2080-IQ4OB4, and 2080-IQ4OV4
Once imported, these function blocks can be used in the same way as native
instruction blocks.
Is there a way to download the program to a Rockwell Micro810 without using the Rockwell CCW application?
726
I'm working on a new project and I have been given an AB Micro800 series plc to work on. I thought it would be similar to the 500 software, but...
25,784
Dear all, I have fx2n plc on my hand but I don't have the programming cable sc-09 and it would not be easy for me to get one. I need the cable...
117
Hi all, i am the new controls guy at the plant and i have inherited a pc from the previous controls guy with Siemens tia portal version 16 and 17...
20
900
I need to pull the program off of an old 90-30 so I can convert it to Allen Bradley. This is my first time messing with GE and I don't have the...
84
