Difference between Modular and Rack Mounted PLC
tahir4awan
Jun 2011
Karachi
23
For a newbie it is difficult to differentiate between these two types of PLCs. What I am able to understand that Modular PLC does have modules but they are fixed and connected together by hard wire.
Rack mounted PLC modules are connected by back plane PCB slots so there is no need to wired them.
Am I right to differentiate them?
Modular and Rack Mounted PLC are not opposite to each other.
Modular is opposite to single unit PLC (a.k.a. brick).
Rack mounted is opposite to rackless (rail) mounting of modules.
In the search field above, enter the following; Unitary, modular, rack-mounted PLC. You'll find plenty of explanation as well as opinions on the caliber of the so-called teachers who continue to force their students to memorize such meaningless trivia instead of concentrating on teaching them how to use one of the most important tools of automation.
Hello, I have a problem with AO- and AA-Tags. When I use for example the tag AO_Test with the address 200 and type the value 1,2 in, the AA-Tag...
1,452
As per the title. This might seem like a basic question to many, but I'm unclear about the difference between a coil ( ) and an application...
28
4,153
Good Morning , I have 2 Frequency Drive panels to build and commission . It is for 2 pump systems . Just wondering , what is the...
2,001
Hi Experts, Good day! What are the differences between PCS7 SIMATIC Batch and PM Control? Do you have any manual like "Getting Started "...
835
I have a Automation Direct Click Plus that you can buy option CPU slot modules for input/outputs. The slot modules have the options of sinking...
2,886
