Go online but not change program? (PLC5)
dalem
Sep 2005
NE Wisconsin
104
I have been instructed to teach one of my maintenance guys on each shift to hook up a laptop to a couple PLC5s, so that they can trouble shoot problems like I do, so that they don't have to call me at 3:00am. (We have some SLCs also, so I may need to do them too.)
I will also need to teach them how to read through the logic to find a problem if needed, but what scares me most is that one could mess up the program unintentially or modify it intentially.
Are there any programs which just allows one to go online and watch all that's happening or would it be best to just use my RSLogix5 and do something with the password features? I have not read much on using the password features in RSLogix, so I'm just looking for suggestions at this point.
Thanks in advance,
Dale
RSLadder 5 and RSLadder 500 may be a good choice. These sometimes are shipped on RSLinx Classic. Check your RSLinx CD to see if you can find it there. It's an online/offline viewer only. I don't remember if data tables can be changed.
Usually I just read other posts on here but I simply cannot find the answer to my problem this time. I have a PLC-5 40E. There is a PID that...
3,005
Hi , I am working on Siemens CPU 315-2DP(6es7315-2af03-0ab0) while working online i try to modify bool value memory address M33.3,M34.0 but it is...
2,326
Hi Friends, I intend to carry out Online thermocouple Module Configuration Change on RSLogix5000 (Compact Logix L35E). Is there any special...
1,271
Hi Friends, A quick one please. Can online changing of Thermocouple Type K to J (configuration change in 1769 IT6/A module) fault compactLogix...
3,774
Hi Guys, We have to open the discussion in our company if its a possible to change the controller name in Control/Compact Logix in Run mode of...
2,028
