Reverse Rotation on 120VAC Motor
If the motor has a starting capacitor on it, there should be some leads marked T5 and T8. Swap these two wires. If they are not numbered,they may be color coded. There could (should) be a legend plate on the motor to identify which two leads to change. Look inside the wiring junction box also for information. If it doesn't have a starting capacitor, you may need to take it to a motor rewind shop to get it changed. In some instances, you can change ends of one of the windings internally to do this.
Basically I need this motor to be able to run forward and reverse all the time. So if the motor does have a starting capacitor am I able to wire a motor starter relay for forward and reverse.
Yes, if it has a starting capacitor you can wire forward and reverse relays. The capacitor is switched out of the circuit once the motor is started.
If the motor uses a shaded pole instead of a capacitor then you are probably out of luck, you will need to replace the motor with a reversible one.
I know that some motors have a centrifugal switch that disconnects the start capacitor once it rotates past a certain speed. While it may be possible to wire the start capacitor for forward and reverse, I'm thinking that you may have to go to a stop before reversing directions.
U r right the motor has 2 at lease slow down until the governor kicks back in then it will reverse. This puts the start winding back into the circuit.
On any across line motor I would let it come to complete stop before reversing. The other thing to consider is heating and possible burnout of the motor as a result of frequent starting and stopping. If you are reversing every 10 second I doubt that motor will last long. If every 5 minutes it should be no problem.
Dan Bentler
Hey, this might be a simple question, but I don't think I ever ran into it before. We all know that on 3ph, any two leads can be swapped to...
26
6,739
Hi all, I'm having trouble solving a problem I've been working on for several months, and thought you might like a stab at it. The machine runs...
22
951
I have a SX2 plc and i'm getting 0-10v analog signal,but i need 10bar analog output in 0v can someone explain how its done
543
I'm trying to add on to a safety circuit and trying to make sure this is fail-safe. My safety scanner needs some muting when things aren't running...
819
Hi, I have issue with acs800 starting the motor in reverse for like 5-6 seconds with a max speed of around -220 rpm before it goes to the...
2,002
