Real-time clock???
wiley
Feb 2005
What exactly is meant by a real-time clock when talking about plc's? Do only some plc's have this feature or do all of them. In what applications would you use one??? How do you program the feature?
Wiley,
I would say about 3/4th of the PLC models now have "real-time" clocks. (If it has a clock, it is almost invariably a real-time clock. I have never seen one with an unreal-time clock). The clock will have some bits that are available to the programmer, such as a 1-second, 1-minute, 0.1 second, and so on. foir example, the ALlen-=Bradley SLC 500 brand has a 16-bit "free-running" clock at Status File location S:4. Any of the S:4 bits can be used by a programmer on a rung of his program.
In the harware configuration (Siemens Simatic S7) u can assign a clock memory byte. We use the 6th bit of that byte for pulsing signals, a lamp that must blink, pulse, or how do u name it in english.
The real time clock, I always think of the clock in de CPU module that keeps running, even when there is no power supply.
donno
c ya
A 'real time clock' is a chip, or a small section of a larger chip, insidee the PLC's CPU. It always recieves power even if main power to the PLC rack is off. Using a very accurate crystal oscillator it can keep very accurate date and time, usually to within seconds a month. It is probably called 'real time' because it's time keeping is much more accurate than a ladder program's timers in the long run. It is very similar to the clock chip in your coumputer which keeps time even if it is turned off and unplugged.
The date/time it keeps is available by way of registers. It's setting can be changed from the programming PC and possibly by commands available in the PLC's language. Some programmers may use these to keep a copy of the date/time when some event happens (time stamping). Others may initiate events at a particular date or time. I don't think many of the 'real time clocks' account for 'daylight savings time' and you will see some questions which are asked on how to handle this. Some of the others have pointed out how very accurate pulses produced in addition to the date and time can be used.
when you look in s7 you can change the date and time of the real time clock with pressing the next key:
alt, L, y
there you see the date and time at that the PLC has at that moment and you can change it there then you can use in ob1
the ob1 date_time to put the time in a db and you can use the different bytes for programming a flashing light or something like that
this is an other way for programming that pulse without changing the hardware config
What exactly is, and what isn't, "real time" ?
That is entirely determined by your requirements. If the only thing you need to do is keep track of which day we're on, then a calendar is 'real-time'. Sundials, hour-glasses, egg-timers can all be considered 'real-time' if they meet the needs of the process. I've actually heard some people say that a real-time clock needs to go to millisecond resolution. Well, if you're a physicist measuring particle decay, that's probably about 5 orders of magnitude too coarse.
Ken
Hello. This is one for the Mitsubishi experts. I need to measure the time for a remote device's to return process data sent from the i-QR...
17
2,176
Hi all I thought I had this working but upon doing a checkup a few months after the machine was commissioned, I found that adjusting the RTC via...
1,883
hi all i have used a real time clock to turn on a bit after 1 month. the plc was off for this whole month and when i turned on the plc after a...
1,428
hey, anyone know how to export time from panelview 800 to micro 850 and to compare time? or distinguish various time , like to know which shift...
1,469
Hi again Looking to write date or time values to the RTC in my MicroLogix 1400 In the ladder logic I am using a CPW instruction as per the 1400...
3,296
