Lg master-k10s1 plc
STMS
Jun 2010
Kuilsriver
I’m working on a bottel labeling mc and I need to make a modification on the plc program – need to know the communication pin connections from the 6 pin round mini din to the 9 pin dsub on the pc. I also need to know where I can get the communication software for this plc
thanks Reg Simon
South Africa
I am not familiar with the LG Master PLCs, but this is what I found on Google for the Comm. connections.
http://easyview.tecnobi.it/download...ioniPLC/PLC_Connect_Guide/LG_MASTER-K10S1.pdf
This led me to their Website. http://www.lgis.com/
If you drill down to through to the PLC section and the Master KS10S1, there are a bunch of PDF Documents for it. You will need Programming Software to make any changes. Hopefully you have an Annotated copy of the Program. I did not see a Download for Programming Software on the site, but have a look around. Failing that, I would suggest you contact your LG Supplier in South Africa, and see if they can fix you up.
Stu.....
Hello guys lately I have to deal with Master-K10S1 (LG PLC) I used to deal with S7-300 Question: is there a simulation progarme to test the...
3,407
Hi, How to get data from multiple Mitsubishi Q03UDVCPU into master PLC Q03UDVCPU through QJ71E71-100 ?
35
146
Hi i using Kinetik 300 2097 driver control by EIP with using move absolute and incremental for motion , but i want to add same driver and motor as...
95
hello s7-400h and wincc are connected to each other via Ethernet. I need help on how to do time synchronization
79
