How to perform a S7-300 overall Reset
jpcor
Sep 2006
Wavre
I want to reset my S7-300 to default settings (default MPI settings), not just perform a memory reset.
Does anybody know if the hardware reset is possible on a S7-300?
J-P
I may be wrong, but I don't think you can change the MPI setting via a reset. I have always done this by changing the MPI setting on my PC to match the PLC and then downloading a new hardware config with the MPI setting I want.
OK, usually I change MPI settings by downloading a new hardware config.
Problem is that for the moment I can no longer connect to the S7-300 using the MPI interface. That's why I would try to reset the communication to default settings by a hardware reset to see if this solves my problem.
As I remember there is only one thing thats retentive in the CPU even you remove memory card, backup battery or remove CPU from PLC rack: CPU port settings. The only way to change it is to download new hardware or put an memory card with changed port parameters into CPU.
Hello Friends, I am trying to index M Bits, however GX Works2 is not allowing it with following message. https://ibb.co/zPcqj6M...
1,380
Hi, I've searched the forums and none of the previous threads seem to have a solution to my problem. I am using Logix Designer 27.11 Professional...
5,959
Hello all, I have a controLogix running studio5k v.21.03 that I am unable to do a couple of things. First, I cannot perform any online edits. I...
1,512
I am trying to open a project file in RSLogix 5000 V20.04.00 (CPR 9 SR 5). This is what I get in the help: Access denied Check to make sure that...
4,596
Can't perform online edit on a PLC5. My problem is similar to this thread: http://www.plctalk.net/qanda/showthread.php?t=61189 In the Processor...
5,059
