Can't perform online edits Studio5k v.21.03
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Hello all, I have a controLogix running studio5k v.21.03 that I am unable to do a couple of things. First, I cannot perform any online edits. I went into options to see if there was something there....nothing. Under Logic>online edits all are greyed out. Second, when I perform a reference check it will show me the locations where tags are used however, when I double-click them it does nothing. All it does is display this at the bottom of my display:
Any chance the keyswitch is in RUN mode? iirc you need to be in REMOTE RUN in order to make online edits.
At a guess the tag is used in a source protected routine.
Can you make edits to the offline project? I can think of a couple things offhand that will prevent editing period, but nothing other than the keyswitch that would only affect online.
Hi, I've searched the forums and none of the previous threads seem to have a solution to my problem. I am using Logix Designer 27.11 Professional...
5,978
Can't perform online edit on a PLC5. My problem is similar to this thread: http://www.plctalk.net/qanda/showthread.php?t=61189 In the Processor...
5,063
Hello Friends, I am trying to index M Bits, however GX Works2 is not allowing it with following message. https://ibb.co/zPcqj6M...
1,387
I am trying to open a project file in RSLogix 5000 V20.04.00 (CPR 9 SR 5). This is what I get in the help: Access denied Check to make sure that...
4,624
Hello, I'm currently programming a MicroLogix 1400 using RSLogix Micro Starter, and I'm trying to convert a block of LONG values into FLOAT...
4,594
