Versa Pro Printout or Conversion
DuncanC
Dec 2017
Pretoria
Good Day,
I am hoping someone can help me.
I saw from some earlier posts that you converted a Versa Pro program to a pdf file for another member. I am in the same situation.
I have a .flb file that I cannot open with my copy of Proficy to be able to get a printout.
I've attached two projects that I desperately need the printout for.
Any assistance will be greatly appreciated.
Thanking you in advance.
Steve, did you print that from ProficyME? I remember being able to print from VersaPro, but for some reason I cant figure it out in ME.
For some reason, I was not able to import the VersaPro file from DuncanC into PME, so I printed from VP.
Normally I would have imported the project into PME for two reasons. First, I have VersaPro installed on an older computer which I have to find in a dark closet and blow the dust off before each use. Second, when I do try to print from VP, I always forget that it doesn't play nice with the Adobe printer driver and I need to use an alternative pdf printer driver.
Hi. Hopefully for Steve Bailey. I saw from some earlier posts that you converted a Versa Pro program to a pdf file for another member. I am in the...
3,249
When I want to store the hwc file to the PLC an error apears and said the firmware 5.03 is incompatible with versapro, and the minimum version...
3,176
hi where can i download ge versa pro ?
1,630
I have a 90-30 PLC file which I think was developed using Versa Pro (P80 in the Uk)with the file extension .z3x Ive tried opening it with machine...
3,099
Anyone have a GE PLC 90-30 program they would like to give me for training. Really do not care what it does, I just wanted to teach myself this...
6,081
