There is no version of Versa Pro compatible with the old firmware. You would have to use Logicmaster 90 software for the earlier firmware levels. For that, you would also need a program file created with Logicmaster. Logicmaster can not open project files created by Versa Pro.
If you are willing to take a chance, it is possible to bypass the firmware level restrictions that Versa Pro imposes. I don't have the computer with VP booted up at the moment to give you specific instructions, but if can navigate to where you can change Versa Pro settings, one of the settings is what to do about firmware level mismatch. The choices are, prevent download, allow download after warning, and always allow download. The default choice is to prevent download. The older the firmware version, the greater the chance of unpredictable PLC operation, so bypass the restrictions at your own risk.
