1756-IF16 Single Ended/Differential
makoester1
Jun 2015
Indiana
Hello,
I have a 1756-IF16 configured for single-ended current inputs. I plan to add (4) 4-wire density transmitters. The operating manual for the density transmitters indicates that the 4-20mA signal is galvanically isolated. Does anyone see a problem with utilizing a single ended configuration?
https://literature.rockwellautomation.com/idc/groups/literature/documents/um/1756-um009_-en-p.pdf In the above 1756-IF16 document on page 43, it...
4,969
If I am using an 1756-IF16 analog input module, single ended do I have to jumper all iRTN and RTN as shown in the wiring diagram. I have a mixture...
3,590
Please anybody advice me what is the difference of single ended mode and differential mode of control logix analog input module.In what...
2,163
I am trying to spec out some PLC modules for an upcoming project. Our vendor suggested we use a 1756-IF16 analog input module for connecting to...
7,456
351
