Technology Objects in TIA Portal... Positioning
userxyz
May 2002
any
2,768
Hi
I have a 1211C Cpu and a CU250S-vector. I tried to make positioning object... But I can't get it to work... Doe à G120 actually can do TO? Or is this for a new kind of drives?
When ai make such object... Do I have to add a drive or not in the project... It isn't very clear to me...
Thank u
Kind regards
G
Worked for me, At least the config part....
Add drive to project- I used Startdrive cu250s
see below
Hi JRW, Thanks for your reply
Hi JRW, Thanks for your reply,
How do you add the drive ?
Where to make the drive ?
Thanks,
Kind regards,
G
I think
I think in my testing today I tried everything but overlooked basic parameter Drive and I think I was on PTO because it wanted me to configure PWM on 2 outputs all the time...
Telegram 4
I achieved one time to connect encoder by choosing telegram 4, but now when I do it again I cannot select the drive anymore to connect on profinet TO object....
No green mark to apply, remains grey..
pick the correct telegram
Telegram 1 doesnt have an encoder in it
This is odd
This is odd, even when I try in a 1500, something must be wrong in drive config...
I'm not very familiar with HSQ RTUs so I need some help if anyone can give it. I have an RTU that keeps cycling off to where I have to cycle the...
535
when controlling a closed loop stepper motor with a PLC,the PLC doesn't know if the target position is reached or not unless the driver it selfe...
997
Hi guys.Can somebody explain me or give me a practical example what is the fail-safe technology/signals . For what i read it is force plant into...
2,589
Good Afternoon , We had a rough summer with power outages , and I am always looking for a stable UPS system that would " ride us through" an...
1,790
Hi, I have two questions regarding the above software: 1. Does anyone have a simple method for converting the data type LREAL (used in this...
1,723
