S7 Technology Config software questions
CDale1989
Feb 2017
Newcastle
I have two questions regarding the above software:
1. Does anyone have a simple method for converting the data type LREAL (used in this case for the encoder total offset value) to and INT or similar? When using the read parameter function i get 2xDWORD
2. I am trying to use the 'Save and Restore Variables' function. When doing so, i can save the variables ok. The variables are saved to .xml files within separate folders for each axis. When tying to restore the variables i am asked to choose a 'file' rather than a folder as described in the help documents (see below). I can only choose a file, when choosing one of the individual .xml files belonging to a single axis i get multiple errors relating to the fact that the function cannot find the variables for all of the other axes and the function fails.
Requirements:
The variable are saved using the Save variables function.
The project is loaded in the target system.
The technology CPU is in STOP mode.
S7T Config is in online mode
How to restore variables:
Select the technology in the project navigator window of S7T Config.
Select the Restore variables function from the shortcut menu.
In the Restore variables dialog, select the required settings and click OK.
In the dialog that follows, select the folder in which backup files are stored.
Note
Do not select the folder which contains the designation Technology, but instead the folder one level above this, otherwise the restore process will not function properly.
Confirm the window that follows with OK.
The variables are restored.
Any help would be greatly appreciated
Chris
I'm not very familiar with HSQ RTUs so I need some help if anyone can give it. I have an RTU that keeps cycling off to where I have to cycle the...
523
when controlling a closed loop stepper motor with a PLC,the PLC doesn't know if the target position is reached or not unless the driver it selfe...
991
Hi I have a 1211C Cpu and a CU250S-vector. I tried to make positioning object... But I can't get it to work... Doe à G120 actually can do TO? Or...
20
3,022
Hi guys.Can somebody explain me or give me a practical example what is the fail-safe technology/signals . For what i read it is force plant into...
2,551
Good Afternoon , We had a rough summer with power outages , and I am always looking for a stable UPS system that would " ride us through" an...
1,766
