Pc/rs 232 Siemens Converter 6es5 734-1bd20
Chandrashekar
Nov 2005
riyadh
42
Dear sir
Iam here with compaq 1200 laptop with installed siemens S5 plc programming software and siemens PC/RS 232 CONVERTER 6ES5 734-1BD20
Iam asking you How to connect this cable to laptop
This cable has 1 side 15 pins male connector another side 25 pins female connector.I connectted 15 pins side to plc, but another side 25 pins connector how to connect my laptop.my laptop having 9 pins port only
Port Adapter
You need a port adapter. It will adapt your 9 pin serial port to a 25 pin to fit the Siemens cable. I know you are not in the states, but Radio shack here in the states carries them. You may be able to find one at your local electronics dealer.
Port adaptor
I have 1 adaptor with me,it has 1 side 25 pins male connector another side 9 pins female connector.I can use this
pls, suggest me
Well...the 6ES5 734-1BD20 uses only 3 of the pins on the 25D connector so if your adaptor has wired as a minimum...
D25 ________ D9
2 ------------ 3
3 ------------ 2
7 ------------ 5
....then it should work
Connection details
9 pins female connector-25 pins male connector connection details
9 pins maled connector--------25 pins female d connector
1---------------8
2---------------3
3---------------2
4---------------20
5---------------7
6---------------6
7---------------4
8---------------5
9---------------22
that means i can use this connector
thanks
In the following circumstances I always make my cables, using off the shelf cables with wires not needed sometimes makes problems. Just make a 3 conductor cable using the 3 pins stated above with a db25sub on one side and a db9sub on the other.
Port Adapter
Chandrashekar;
That sounds like the adaptor that I use (i just looked at mine to make sure). Just plug it in to the Siemens cable and then into the RS 232/serial port on your laptop and it should work if the software is configured correctly.
Please, if anybody has this Siemens RS422/RS232 Converter. Please inform me. I don't know where I can find a stock of this. Order Code...
1,606
Hi all. I am having trouble getting a Siemens OP277 and an AB SLC504 to talk to each other via DF1. The older panels OP25/OP27/OP270 had an...
2,100
I found the converter 6es5 734-1bd20 in the store of my company. I don't use it before but i know from search in web that this is for step 5...
3,085
I have a Notebook without serial port, I wont to use an USB to RS232 converter to connect the MPI adapter to program Simenens S7300. Is possible...
7,428
Hi i have Beckhoff (CX5020-0120-M310) (profibus master) with TC3.1 and want communicate with Siemens Profibus ET 200S (IM151) DPV1. All modules...
1,703
