SCHNEIDER M340 compatibility
AFPC
Feb 2011
Damascus
Hello Dear friends
I have a DRESSER_RAND generator. A part of the control is taken over by a SCHNEIDER M340 PLC.
The system components are as the following
1- power supply CPS201
2- CPU P3420302
3-DDI6402K
4-DDO6402K
5- AMI0800
6-AMO0410
7-DDI3202K
8-AMI0800
9 AMO0410 BMXAMO0410 PV:01 ,SV:10
I need to order spare parts because we don't have any.
Is there any version considerations?
I could only see the extra information for the last card because I cannot stop the generator to take out the other cards.
Is the information about the other cards enough or different versions can make problems.
I don't have unity PRO software. If I order to purchase it can I retrieve the information about the module including the firmware versions. For some other types of PLC I know I can but I don't know about SCHNEIDER.
Could the program be locked out by DRESSER_RAND so I cannot retrieve or modify anything.
Thank you
I would only worry about the cpu version. You dont want to replace the cpu with an older version, as it may have some extra functions and also certain unity pro version (I think from v8 onwards....now on v12) cannot connect to old cpu version.
The program can indeed be password protected or certain program sections. I would contact Dresser_rand to find out before purchasing any software
I disagree little bit.
Unity will connect also to old versions, problem is that new Unity version have different libraries and it can lead problems. Program cannot be loaded if firmware version is lower on real PLC than that which is selected on PLC program.
Also new programs have newest firmware version selected by default.
If you rebuild whole program and select correct firmwares (Downgrade offline version) you can connect to all CPUs.
Have still Unity version 2.3 builds on some programs, last time I maked online changes with V11. Project is still V2.3 base.
New PLCs and cards have newer firmwares than old ones. They are compabtible without any program modifications.
You can have only problems if you try to change old card with older firmare versions to rack than which is used on program.
If you buy new cards there can't be firmware problems.
Chud, I think that table means
If You use Unity V11 pogram and libraries are selected to V11 base, minimum PLC firmware version is 3.1.
Still if you use V11 program, but select lower libraries on Project then PLC firmware can be lower.
(With V6 libraries selected to project, minimum firmware is 2.9 even that you use newest Unity program.)
Pretty sure that Premium PLC which last time programmed with V11 unity wasn't with firmware 3.1. Project libary was lot lower on program than V11.
You can select libary base for Project if you open sta file.
(Open -> sta -> select library version -> rebuild all)
Hello all, I am wanting to update the system clock via NTP in the M580/M340. I'm aware that we are able to connect to a NTP in the controller...
173
so i have an isssue where if the serial port of an M340 plc disconnect from the screen it would retain the values of the variables being sent...
929
Hello, I'm having a hard time understanding how to get a Modicon M340 to pull a Modbus address from an ABB Totalflow via Ethernet. I set up a port...
1,178
Hello, this is a message for specialists in Schneider, I am trying to establish communication in modbus tcp between a schneider M340 (P3420302)...
1,630
I need to establish communication between Schneider M340 and S7-1500 PLC. I am using gateway converter for MODBUS TCP TO PROFINET protocol...
3,040
