Citect SCADA 7.4 SP 2 - CTAPI stops working after some time
agoslinski
Jun 2016
Poznan
Hello
On my Citect SCADA server I have few python scripts that read and write data to Citect using CTAPI.
I have a problem that after some time(hour or two) SOME (not all)of my scripts are unable to write data to tags.
All my scripts use the same code for connecting to citect (code below).
Restarting Citect Client service helps for some time.
Code:
from ctypes import *
import os
import sys
import servicemanager
import win32api
class CTAPI:
    def __init__(self, dll_path):
        os.chdir(dll_path)
        self.CtApi = WinDLL("CtApi")
        self.Ct_ipc = WinDLL("Ct_ipc")
        self.CiDebugHelp = WinDLL("CiDebugHelp")
        self.CtEng32 = WinDLL("CtEng32")
        self.CtRes32 = WinDLL("CtRes32")
        self.CtUtil32 = WinDLL("CtUtil32")
        self.hCTAPI = None
    def ct_open(self, address, user_name, password):
        if self.hCTAPI is not None:
            servicemanager.LogInfoMsg("Already connected")
            return
        self.hCTAPI = windll.CtApi.ctOpen(address, user_name, password, 0)
        if self.hCTAPI is None:
            servicemanager.LogInfoMsg("Connection failed")
            return
    def ct_close(self):
        windll.CtApi.ctClose(self.hCTAPI)
        self.hCTAPI = None
    def ct_tag_read(self, tag_name):
        buffer = create_string_buffer('\000' * 32)
        ok = windll.CtApi.ctTagRead(self.hCTAPI, tag_name, byref(buffer), sizeof(buffer))
        if ok is False:
            print("Unable to read TAG")
            return
        return buffer.value
    def ct_tag_write(self, tag_name, value):
        while self.write_lock is True:
            pass
        self.write_lock = True
        ok = windll.CtApi.ctTagWrite(self.hCTAPI, tag_name, value)
        if ok == 0:
            e = win32api.GetLastError()
            try:
                f = hex(e)
                f -= 0x10000000
                g = int(f)
                    "Unable to write: " + tag_name + ": " + str(value) + " Error: " + str(g) + "(" + str(e) + ")")
                print("Unable to write: " + tag_name + ": " + str(value) + " Error: " + str(g) + "(" + str(e) + ")")
            except:
                    "Unable to write: " + tag_name + ": " + str(value) + " Error: " + str(e))
                print("Unable to write: " + tag_name + ": " + str(value) + " Error: " + str(e))
        self.write_lock = False
Hare are some errors from citect log files:
[ipc.log]
IPC: IPCSocketReceive (recv detected that the peer closed connection gracefully), error: 0xe9
CtApi Server: Win32CAPIWaitForCmd: IPCRead failed. 0x2736 (instance id = 11152)
[tracelog.dat]
Cannot perform TagReadProperty operation on Unresolved Tag=TAG_AiB_R_2_42_L2_18_Status_Bledu (this tag is working I don't know why it is unresolved)
Do You have any idea what could be the cause of ctapi not working after some time?
Best regards
Hello, the system we use is Scada 7.5 series. We have usb key activ now we need additional key to make the system work, how do we solve this...
68
79
I am trying to display a variable within a cicode function onto a graphics page. This function queries a SQL database. I can get the value onto a...
331
We are trying to set up a newer generation Omron PLC (NX/NS Series) with Citect / Aveva Plant SCADA using the Ethernet/IP CIP Protocol to read...
417
I am new to Citect SCADA and I am building the graphics for a page that will contain the control of a plant by a Kingfisher RTU. The project I...
289
