Citect SCADA ver 7.5 with Kingfisher RTU
integration
Feb 2024
Australia
I am new to Citect SCADA and I am building the graphics for a page that will contain the control of a plant by a Kingfisher RTU.
The project I am working on already contains a page that had been previously designed and controlled by a Kingfisher RTU.
When I attempt to compile the project, it results in the fatal error "
F4027: Unknown protocol - The project you are trying to compile refers to a protocol that does not exist. "
Is there something I am missing when using Kingfisher and Citect SCADA?
We are trying to set up a newer generation Omron PLC (NX/NS Series) with Citect / Aveva Plant SCADA using the Ethernet/IP CIP Protocol to read...
362
Hi Friends, I have a Vijeocitect SCADA system with One Primary Server, One Secondary, and Two Client Severs, all running on Windows XP Pro...
2,082
Hi Friends, I have a Vijeo Citect SCADA Redundancy issue and I believe some Friends here might have had the experience before now. I will be...
2,272
Hi Friends, I'm working on a Redundancy discrepancy on our VijeoCitect SCADA, The Primary can not take over when the Secondary Server goes down...
1,291
I have to connect more than 50 no of modbus TCP/IP IO devices to Citect SCADA. I will be connecting them as individual ports. Can I give different...
1,907
