VijeoCitect SCADA Pri/Sec Server Redundancy Discrepancy
IdealDan
May 2017
MA
480
Hi Friends,
I'm working on a Redundancy discrepancy on our VijeoCitect SCADA, The Primary can not take over when the Secondary Server goes down.
I have checked the Citect .ini file bearing the configuration settings for the Primary server with the Back up .ini file. All configuration seems ok.
Please guys, have you come across this? if yes, please what is the possible fix?
Thanks in advance for your input
Hi Friends, I have a Vijeocitect SCADA system with One Primary Server, One Secondary, and Two Client Severs, all running on Windows XP Pro...
2,082
Hello all, I got a call yesterday from a worker at a factory where i installed an automation sistem with a PLC M340, operated via SCADA Vijeo...
4,809
I am using VijeoCitect v7.5 on Desktop having Windows-7 OS. While viewing trends, it is observed that trend is not appearing continuous and value...
553
Hello folks, i bring you a new problem to be solved.. Situation: we have 2 PLC M340, 2 PC's running 1 vijeo citect license + 1 ofs opc each. for...
1,879
Hi, In VijeoCitect V7.2 we can filter alarms as per category and display them on Alarm Summary page. But my Customer wants alarms for every...
3,354
