Citect SCADA - Configure different Modbus driver polling rates
kpdesheeb
Aug 2013
I have to connect more than 50 no of modbus TCP/IP IO devices to Citect SCADA. I will be connecting them as individual ports. Can I give different polling rate for each of them in using citect.ini file? Or by any other means?
I am trying to display a variable within a cicode function onto a graphics page. This function queries a SQL database. I can get the value onto a...
291
We are trying to set up a newer generation Omron PLC (NX/NS Series) with Citect / Aveva Plant SCADA using the Ethernet/IP CIP Protocol to read...
362
I am new to Citect SCADA and I am building the graphics for a page that will contain the control of a plant by a Kingfisher RTU. The project I...
270
Hi All, I aim to use Aveva Plant SCADA 2020 to read and write data from/to Omron CJ2M CPU35 PLC using OMFINS protocol. However I have Bad Data...
730
