NPN Vs PNP Proximities???
Eswar
May 2006
hello all.
I have a diubt regarding the subject (NPN Vs PNP Proximities)...
I learnt from a source that NPN is a sinking and PNP is sourcing..
I like to know whether NPN kind of proximity should be connected to a sourcing input module and the vice versa for PNP???
Also can we connect NPN kind of proximity with a sinking Input module by just interchanging the power terminals (i.e) the + and the - of the proximity...
Thanks in advance
Rgds
Eswar
Eswar said:
hello all.
Thanks in advance
Rgds
Eswar
You are right about the first question - NPN Proxi -> Sourcing I/P Module.
2nd Question -> I doubt you can convert the proxi by interchanging the + and -.
But I do come across Festo reed switch (3 wire type) can convert from PNP to NPN by interchanging the power cords (Brown and Blue). But for a person who do not know of this will take it as weird, while trouble-shooting.
__________
Maybe this will help; http://www.patchn.com/npnpnp.htm
All these terms are relativistic to how current flows. A PNP device could replace an NPN but if will invert the signal. Example; where an NPN would be ON and provide an input to the PLC the PNP would be OFF and provide no signal.
It depends on the situation but PULL UP or PULL DOWN resistors may be used to change from NPN to PNP or vice versa. This may help understand their use; http://www.seattlerobotics.org/encoder/mar97/basics.htmlhttp://www.patchn.com/npnpnp.htm
There are numerous threads available here on this subject;
http://www.plctalk.net/qanda/showthread.php?t=19281&highlight=NPN
http://www.plctalk.net/qanda/showthread.php?t=1615
Eswar said:
hello all.
Eswar
Yes, as long as you mean a signal source, that is a sensor.
Eswar
Yes for Allen Bradley. No for Mitsubishi.
For other brands it may be yes or no, you need to see the specs and sample diagrams.
Eswar
No, do not even try this.
Never reverse the power polarity for electronic circuits.
Hi to All, How I can change NPN to PNP solid state switch? Exapmle1: D-M9N Solid state switch with D-M9P Exapmle2: or allen bradley p.e.c. type...
1,451
Hello; I have noticed one thing more that some time OEM selected NPN PLC I/Os instead of PNP while with PNP the trouble shooting is easy. This...
3,626
I moved my Shopbot and the only problem that I had was a broken proximity sensor. I found a replacement sensor...
1,806
hello,any body can design pnp to npn converter to use plc ,you know plc's work with 4 to 20 mA and 0 to 48 DC volt or 0 to 120 AC voltage...
1,675
