plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 7th, 2018, 09:01 PM   #1
backendcode
Canada
backendcode is offline
Implement logic! need help please
Hello guys, Just wondering if someone can help me please
I have a timer when gets enable I move .acc value of that timer to another tag to store the .acc value but next time when the timer gets enable again, it overwrites the last stored value of .acc into that tag.
but I would like to add the new accumulator value of that timer to existing value of my tag where I am storing .acc value.
Or is there any timer which keeps the value of .acc (Don't set to zero) when become disable and I can reset that .acc value at 7 am which I will use GSV instruction to get that time.
Thank you,
__________________
Junior Control Engineer
Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live
Old February 7th, 2018, 09:05 PM   #2
bkottaras
United States
bkottaras is offline
Quote:
Retentive Timer RTON
Old February 7th, 2018, 10:08 PM   #3
backendcode
Canada
Thank you
__________________
Old February 8th, 2018, 05:48 AM   #4
daba
United Kingdom
daba is offline
daba's Avatar
It is just RTO - not RTON.
It works exactly the same as a TON, except that it doesn't automatically reset when disabled. To reset it, use the RES instruction, with the timer tag name as the parameter.
It sounds like you don't ever want it to "time-out", because if it did it would just "freeze" with the .DN bit set, and will not accumulate any more time. Set the .PRE to 2,147,483,647 (maximum positive value of a DINT), which equates to 2,147,483 seconds, or just under 25 days of accumulated time.
The good thing about using RTO is that it will hold the accumulator value, not just when it is disabled, but also through power-cycles, and mode changes (RUN-PROG-RUN) of the controller, that is why it is called a "Retentive" timer.
__________________
___________________________
ControlLogix & SLC Training
a-b train ltd.
abtrain@tiscali.co.uk
www.abtrain.co.uk
tel: 07506 73 9999
nil illegitimi carborundem
Old February 8th, 2018, 11:38 AM   #5
backendcode
Canada
Thank you for the explanation! Much appreciated and I finished the logic and its working good so far
Thank you again for the help
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
What can i do to get better at coding controls logics? Jrivers010 LIVE PLC Questions And Answers 54 August 23rd, 2017 06:08 PM
Direct Logic H2-CTRIO help please Tubularfab LIVE PLC Questions And Answers 18 June 5th, 2012 04:44 PM
How can i implement the logic jcp LIVE PLC Questions And Answers 11 October 11th, 2011 08:30 AM
Ladder Logic, Line-by-Line, Flowcharting recondaddy LIVE PLC Questions And Answers 10 March 18th, 2010 11:39 PM
Motor control programs in laddar logic richie LIVE PLC Questions And Answers 7 August 18th, 2005 10:26 PM
