Eduardo Pelegrin
- Join Date
- Apr 2003
- Posts
- 25
I need this help.FB 250 is used in S5(115U) PLC for analog readings. Parameters UGR and OGR are used to set Min and Max Ranges.I can see that the only way of setting these parameters is by mean of KF Format (a constant number). Is there any way of changing these parameters using for example a DW to change the range is required?
Thanks in advance
Eduardo
Thanks in advance
Eduardo
