S5 Analog Reading
Apr 2003
25
I need this help.FB 250 is used in S5(115U) PLC for analog readings. Parameters UGR and OGR are used to set Min and Max Ranges.I can see that the only way of setting these parameters is by mean of KF Format (a constant number). Is there any way of changing these parameters using for example a DW to change the range is required?
Thanks in advance
Eduardo
Hola, Sr. Pelegrin;
It seems that the input format of the OGR and UGR parameters of FB250 are hard-coded; it will not accept an address as a prameter value.
We use several conditionnal calls to FB250/FB251 when we need to setup different ranges, each instance call configured with different limit values. The tough part is programming the logic to use the correct instance when we need it.
Hope this helps,
Daniel Chartier
I am setting up a new system and have an s7 1214 plc with an sm1231 4x AI (6ES71231-4HD32-0XB0). It is configured for 0-10v and has no faults in...
1,168
I'm pretty new to Siemens. I just downloaded a new program into a new S7-1500 CPU. All modules are ok/not faulted. here is the problem: i have 4...
2,947
I just added a 1746-NI4 in remote rack slot 9 and ch0 is set to 0-10V input. Now I am trying to read the AI and the value getting back from BTR is...
2,271
I need some help. I have a 1769-IF4 analog card that is hooked up to strain gages, the gages give a 4-20ma signal to the card. We had an...
2,055
Hi all! Is someone can help me to understand what they means ? This is the only info I could find on my device : With this module is possile to...
2,355
