Analog way to closed contact after a certain number of counts
BrockSamson
Feb 2019
Pennsylvania
30
I have a machine that cycles for about 15 seconds on and 5 seconds off continuously, the timing is controlled by cams. I want to add something that will use a pneumatic solenoid valve. I need this solenoid valve to only turn on after x many cycles. For example, on the fifth cycle of the machine, the solenoid valve will open for a few seconds.
Now the machine does not have any type of controller. I have a relay that only switches on while the machine is on during its cycle.
I know this would be simple using some type of programmable controller but its overkill.
I need a simple, cheap analog solution. Do they make any type of simple devices close contacts on a certain count and then reset. I searched for counters but Google has not helped me.
Thanks guys looks like that should work. It is a bit pricey but it might have to do.
Edit: Now that i know what i am looking for i found some cheaper ones.
Hi looking to install a smaller less sophisticated PLC for fountain timing and also one analog pressure sensor which would be used to detect...
23
628
Hi all. I have 1793-IE4 (4)analog inputs modules in a 1794-ADN IOFlex DeviceNet Rack. I cannot find if I can I have access to individual channel...
75
Good afternoon, I am currently working with an HMI/PLC LP-a070 and I require at least one analog output, but the PLC does not have one. I was...
152
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
256
I'm having trouble calming down 2 Tempo Sonics. I'm using Studio 5000 CompactLogix my Raw value is jumping around from 8575.0 to 8755.0 at a...
30
1,250
