Data type TIME access via Indirect Addressing with SCL
MOeZ
Nov 2009
singapore
101
I am facing invalid data type when i compile SCL and no luck in finding any old threads? could point me out to right direction?
Thanks.
TIME_OUT : TIME ;
WORD_TO_BLOCK_DB(INT_TO_WORD(DB_Num)).DD[4] := TIME_OUT ;
Using the AT keyword is one solution:
Code:
FUNCTION fc89:VOID
VAR_TEMP
    TIME_OUT : TIME ;
    dwTime AT TIME_OUT:DWORD;
    DB_Num:int;
END_VAR;
WORD_TO_BLOCK_DB(INT_TO_WORD(DB_Num)).DD[4] := dwTime ;
END_FUNCTION;
Solved!
Code:
FUNCTION fc89:VOID
VAR_TEMP
    TIME_OUT : TIME ;
    DB_Num:int;
END_VAR;
END_FUNCTION;
Thanks LD and Garry. I have tried data type CHAR as well and it worked.
But can I ask how do know this as I have been reading Siemens manual and didn't find right answer.
I cannot add SLC500 analog input tag (I: 8.3) to EZSeries Touch Panel Editor (V 5.3). I used all the listed tag datatype but it all says "Invalid...
258
Hi guys, I have no experience when working with AllenBradley PLC, but I hope someone could clarify the result of multiplication shown in the...
2,196
Trying to get data types (AS Structures) to update after a new tag import is made from PLC. WinCC can show red if an existing element was removed...
273
Is there a way to use LREAL Data type on L71. I am getting 64 bit Double (IEEE754 Double precision 64-bit) data from a modbus device onto PLC via...
959
