Large numeric displays
ASF
Jun 2012
Australia
3,921
Hi all,
Got a customer that wants a large 4 digit numeric display so that an operator driving an excavator can see how much weight he's already loaded without having to get out. So I'm envisioning something brightly illuminated and about 300mm high. I'll need four of them in the end, and wondering if anyone has any suggestions?
Ideally - and this is probably asking way too much - they'd be ethernet-based so that I can just send them the number directly from the PLC (MicroLogix 1400) and have no discrepancy between the number on the operator's HMI and the number on the large display. But if that's not possible, then I'll just have to do 4-20mA and calibrate it up as best I can.
Has anyone seen anything like this?
Thanks!
Prescision Digital has some bright displays. If not Regular 7 segment display using an out to BCD command. Would take a few extra outputs but definitely doable.
Have you thought about putting a smaller display/control in the machine with the operator?
An iPad with scadamobile would not only provide a display but can also give the operator some control at a very reasonable price. Just a thought .
I used the 7" version of these on a recent project:
http://store.qkits.com/moreinfo.cfm/MXA004
They're true 7-segment displays, so they will require seven outputs per digit, eight if you want to use the decimal point. They're light-of-a-thousand-suns bright too; painful to look at bright. Definitely daylight readable. You'd have to of course figure out a mounting scheme, as they're PCB's with no housing.
I used an AutomationDirect DL-06, which has the SEG command; it reads a BCD register and properly formats it to a series of outputs. Does the MicroLogix have a similar command?
-rpoet
Thanks for the tips so far!
Jane - I can't find anything on precision digital's website that large - do you have a particular unit in mind?
Charles - a little small but plausible. I'll see if they think that would be big enough for them
Doug - that's exactly the sort of thing I'm after - any idea who sells displays of that size commercially? (instead of, as seems to be the case there, custom making them for certain industries)
Ndzied/Kellian - jackpot! That sort of thing would be perfect, although I'm sure it's not cheap. But it's a great option to be able to throw at them
James/Chelton - they don't want a display inside the excavator as it might not be the same excavator every day. And on this site, a tablet or mobile solution would not survive long - it'd be lost, smashed, or buried in a pile of concentrated lead powder within a month ;)
rpoet - I think the ML1400 has a similar command, but...4 displays at 4 digits each, with 7 outputs per digit...that's 112 outputs and a huuuuuge multicore ;)
I know with larger motors you do not want them to start with a contactor above 30HP or so because they will 'sag' the power in the plant and the...
824
Hello, I'm digging all over the internet to find a solution for this but haven't come up with anything yet. We have 3 nearly identical machines...
960
Hi All, On my site, the standard template for storing recipes in the PLC is to create a tag called PartRecipe which is an 2D array - for example...
1,471
We have a panel with a 125HP VFD. We need to run #3/0 wire from the disconnect to the VFD & line reactor. The normal stuff is hard to bend and...
2,786
Working on an upgrade project, going to replace an L63 revision 17 with an L74 revision 30. In newer L74, MSGs with large tags as source/target...
771
