Servo Motor Y-1002-1-H00AA Encoder to Ultra3000i wiring.
yam785
Jul 2004
pa.
153
I am working on a demo unit, which has a Y-1002-1-H00AA Servo Motor.
The demo unit originally had a Ultra drive 1398-DDM-005 controlling the above mentioned motor. This drive has a parallel type plug for the encoder feedback. I was tasked with changing the drive to a Ultra 3000i 2098-DSD-020-SE, which has a 15pin D-Shell. I have a cable with the 15pin D-Shell connector, but it does not plug into the cable coming from the motor encoder. I was told to splice the two cables. I just want to make absolutely sure of the pin-out, before I start. I am especially confused about where the "Hall" wires should be pinned to. As splicing the two will involve some time, I prefer to only do it once.
Any help would be greatly appreciated.
When migrating from the older Ultra 100/200 (aka Electrocraft BRU) to the Ultra 3000 you need to purchase new feedback cables. Most of the motors had the Hall effect sensors installed, but the older drives didn't use them and so the old cables didn't include wires for them.
Thanks Gerry. I do have the new 15pin D-Shell cable for the ultra3000 drive, but I'm not sure what pins the 'Hall' wiring should go to.
Hi all, New here and new all round to PLC`s. We have a servo drive that runs a cross travel beam backwards and forwards. I am having trouble with...
198
My servo motor instruction is not being executed on the gx works 3 even after the positioning parameters have been set
122
Hi All. I am setting up an Omron 1S Servo Motor to drive a conveyor. It goes forward 200mm, pauses and repeats until it is stopped. However...
749
Hi all, I am having a problem with my servo motor and I'm absolutely stuck as to why it wont run. Without any gearbox or any load attached to...
3,702
We are currently experiencing a fault on 1 of the 3 stepper motors, keying mismatch fault. The stepper motor is SMD23E2-240A-M12S. We bought the...
1,355
