Omron 1S Servo Motor Target Position Setting Out of Range
sasi8hk
Mar 2022
Melbourne
Hi All.
I am setting up an Omron 1S Servo Motor to drive a conveyor. It goes forward 200mm, pauses and repeats until it is stopped.
However, after some time, the Servo goes into fault: Target Position Out of Range.
I believe that this is because the encoder count is close to the limit and the 200mm will send the count to overflow. I have used MoveRelative and MoveAbsolute functions. But the issue is still there.
Is there a way to reset the count? Or is there a proper function that does this? Thanks.
Thanks Bobo. I will give it a try.
There are many move functions and I find the descriptions and the differences between the functions to be very vague.
How do you get a target position out of range error? Are there extend and retract limits?
Can you log exactly what the target position was when the error occurred?
Delta Motion and Rockwell have the concept of an "unwind" position which would be 200mm in your case. When the motor gets to 200 mm it automatically resets to 0 but not by resetting hardware counters.
These kinds of problems occur with rotatory applications too. Commands need to be able to indicate if moving positive, negative, nearest, absolute etc. as this affects which direction the target will move when going to the next position.
Good Morning: Our company as a Miic Tube bender, dated 1991, which has several Omron Servo Motors. One of these, a R88M-H50030, 500 watt unit has...
4,911
i am new member of the electrical team of our company and as task i was incharged of the controls of an urgent project..one of my problem was how...
8,382
I work for a used industrial machinery merchant. We try to get uploads from all our machines for future customer support and security. We have a...
847
Hello, I am doing a positioning application for a paint spray machine. The horizontal indexing of the paint gun is done by a Tooth belt axis...
1,684
Good day, I am having a problem with outputting pulse to the HIWIN servo driver using the OMRON NC113 module. The NC113 module is already...
3,741
