OMRON NC113 Module to HIWIN Servo Driver
romerqazwsx
Sep 2018
Laguna
Good day,
I am having a problem with outputting pulse to the HIWIN servo driver using the OMRON NC113 module.
The NC113 module is already outputting a pulse but the HIWIN servo driver wont recognize it. I am already sure about the settings on both the NC113 and HIWIN servo driver.
Here is my wiring.
NC113 Wiring (open pulse collector):
Here is the wiring on my HIWIN servo driver:
I9 and I10 ports are described on the manual as:
and the manual gave this wiring when using pulse command through host controller (single end) which is A6 and A8 on NC113:
This is the parameter setting on the HIWIN servo driver:
Thank you very much in advance!!!
3,454
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
174
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
64
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
110
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
261
