PLC CP1L with CJ1W-CIF12 connected to OMRON MX2 drivers
joserc
Mar 2010
Almeria
Hello,
I have an installation with an omron plc CP1L with a CJ1W-CIF12 module connected to eight omron MX2 drivers. I use the bus to modify the speed of the drivers from the PLC. In the plc I am using an omron function called "Modbus_MX2" and it seems that everything works fine because it is possible to change the speed in any of the drivers. However, when the drivers are active and I send a new speed reference to any them, it takes between 15 to 20 second for the driver to take the new speed. The port in the plc is configured with this settings 115200,8,1,N Serial gateway. I would like to know if this response time is normal with this configuration. If not, I would like to know what could be causing such an slow response. Thank you very much in advance. Regards
This sounds like a programming issue. There must be timers that will poll each of the drives.
Can you post the program or the part dealing with the communication?
Regards,
Hello, I am afraid that I do not know how to post code here. If it helps I can tell you that in the code I am just using an Omron functio called INV002_Refresh_X31 that I call in every program and it is always enabled (P_On). In the input Interval count I have a value of 10. Thanks.
hello guys... I have done communication with omron cp1l plc and yasakawa v1000 ac drive now I'm able to write drive parameter from plc program...
3,081
Converting the actual program was not a problem. However, when I tried to open my memory file from the CPM1 on the new CP1L I got a message "The...
2,325
Good afternoon, I need to create a recipes display on the hmi ns8, to change the parameters of a servo and some strings . The PLC that im using is...
2,776
I have a problem with my machine....we are using Omron CP1L PLC with a set of temperature controllers and Hakko HMI to control a set of 16...
2,344
Hi all. New to this PLC programming so bear with me please. I am using an OMRON SYSMAC CP1L plc with cx-programmer. Needing a part of my program...
1,832
