CP1L Omron PLC
kumar75
Feb 2014
klang
I have a problem with my machine....we are using Omron CP1L PLC with a set of temperature controllers and Hakko HMI to control a set of 16 independent heaters.....problem is some of my heaters PV temperature are fluctuating +- 16 deg C......is there any way to modify the plc program to reduce these fluctuations.....
Pleased to hear
Cheers
Kumar
Hello, I have an installation with an omron plc CP1L with a CJ1W-CIF12 module connected to eight omron MX2 drivers. I use the bus to modify the...
2,151
Good afternoon, I need to create a recipes display on the hmi ns8, to change the parameters of a servo and some strings . The PLC that im using is...
2,772
In the hand position: Pumps 1 and 2 are controlled and alternated by the hand selector switch. When Hand position is first selected, pump 1...
3,595
Not able to connect to OMRON CP1L-EM PLC, I want to restore factory default ethernet address settings and port settings. Please suggest how can I...
2,276
Hello, Does anyone knows how to get the current PV of the timers and counters for Omron CP1L PLC? That would be great if can have some examples...
7,130
