![]() ![]() ![]() ![]() This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
Hi everyone. I just got the new factorytalk view ME V5 software.
I exported the Rs logix5000 tags inti a CSV file. In factorytalk I tried to import but it must be in a .med format. Huh Does anyone know how to get the tags into factorytalk view ME please? ![]() |
#2 |
No need to import the tags. Read the manual on direct referencing.
You can tell the object on the screen to look at the tag in the PLC direct. You do not need to run a tag database in the Panelview. Regards Alan Case |
#3 |
If you want on the tool bar under tools there is a tag import/export tool.
#4 |
Alan looks like that will only work if you are online, Thanks but the machine is 30min away getting built. Is there any other way.
#5 |
Smoke yea but it only imports .med files HUH???
#6 |
If you tell it where your offline files (PLC logix file)are on your hard drive you can direct reference them, then when the real PLC is there the PV will automatically look at them instead of the offline file.
Regards Alan Case |
#7 | |
![]() ![]() Join Date: Oct 2005
Quote:
A123237175 - Using an RSLogix5000 .ACD file for offline browsing Look for this tech note application doc on the aB web site.It will walk you through the entire setup. |
#8 | |
Quote:
The ACD file MUST be on your local machine not a network drive, etc. |
#9 |
#10 |
![]() ![]() Join Date: Jul 2009
你好,Failed to import the file, "name.L5X". The specified L5X file is not targeted for this import context.我怎么处理?
#11 |
Not sure I remember but I think .L5X extension is for Transaction manager.
#12 |
Thanks Alan. I have made the tags available as offline. Works. Cheers for your professional response.
#13 |
Smoke I don't think you understand the problem mate. Maybe you haven't read the whole forum.
Last edited by rigicon; August 13th, 2009 at 05:34 AM. Reason: Forgot persons name. |
#15 |
Hi.
Its nice to get a reply of thanks when something works. Regards Alan Case |
Bookmarks |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Rockwell FactoryTalk View SE V4 Schema fails | mcummins | LIVE PLC Questions And Answers | 1 | June 11th, 2010 10:06 AM |
Device Based Alarming in FactoryTalk View SE | stuofsci02 | LIVE PLC Questions And Answers | 4 | September 11th, 2008 03:25 PM |
Troubles with tags in RS View Studio ME 4.00 | AleksF | LIVE PLC Questions And Answers | 4 | June 13th, 2008 11:31 AM |
RS View Studio using DATA Server tags | randy741985 | LIVE PLC Questions And Answers | 3 | May 11th, 2007 04:14 PM |
RS View Machine- Missing Tags | Coachman | LIVE PLC Questions And Answers | 5 | October 30th, 2006 09:06 AM |
