GE PLC CPE305 USB problem
Go to this site.
Search for GFK2222.
The top result is the manual you need.
You will have to register to download the manual.
Section 2.1.7 discusses the use of a USB.
IC695CPE305 and USB
The IPI (Datasheet) details the USB operation also.
Be aware that putting the Project onto a USB drive is only useful for placing it back to this or another CPU as for some unknown reason Proficy ME does not support the format used here, unless maybw the new version 9.5 of PME does.
I have a problem loading the first configuration and logic to a new CPE305. This is about the 20th CPE305 I have setup. I have never had a big...
18
8,250
118
the conveyor can stop because of a safety sensor or safety switch. And also it can stop because of an object jam detector sensor. If the conveyor...
176
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
36
230
