1756-EN3TR unknown in I/O configure on Rslogix 5000 v20
suboliu
Oct 2010
windsor
266
Recently reinstall win7 32bit and reinstall Rslogix5000 v20 and open pre logix program, but its I/O configure display unknown 1756-EN3TR, I downloaded EDS files and 1756-EN3TR v5.08 from AB and reinstall them. when open program, it still displays unknown.
who know why and reasons.
any help is appreciate!
^....EDS files are for linx only. You need the AOP for RSLogix 5000 to recognize ENxT and TR modules.
Yes but does your ent3r have firmware 10 loaded in it or an earlier version? AOPs aren't accumulative...they don't have all the prior revisions...they are specific to the firmware revision in the module.
I download aop for 1756-enxtr version 10. and installed, still unknown. and another laptop can display that it is v10.01. but this laptop can't display
Did you try rebooting your laptop? Usually you don't need to do that, but you can try it.
If the difference is just the minor revision, you'd have to see the module on the I/O tree. Then you can select the compatibility mode in the module properties.
TN575816 Add-On profile (AOP) for 1756-EN2T series D, 1756-EN2TR series C, 1756-EN3TR series B (Access Level: Everyone)
Hello nhatsen,
Thank you very much!
from your this link, why I can only download AOP for 1756-ENxTR V10.00.00
and you show me that it is V10.001
see attach
I download v10.00, and installed, but still unknown. have any idea?
Hello nhatsen,
from this download link that you gave, I download it (v10.00.00 can't see v10.00.01) and downloaded it and installed it. the I/O tree still shows "Unknown"
any idea?
Hi all I have a ControlLogix 1756-L71SP that i want to use for general PLC applications, not safety. I am running Studio5000 v33, i can't...
98
421
Hi, I have two quick questions: 1- Could I use 1756-IA16/A with TTL inputs? Sourcing (PNP)? Sinking (NPN)? Either one? 2- What does /A in the part...
183
Hi all, installed on chassis A17 an A/I from Allen-Bradley , problem is what ever I do , all channels are sticked on value 39.9 and cannot change...
161
Hi, Is it possible to for an RIO with Flex 5000 series module, e.g. 5094-AEN2TR, to communicate with an 1756-L72E processor.
103
