1756-EN3TR unknown in I/O configure on Rslogix 5000 v20
Go into rslinx, find the module, right click on it....what firmware dies the module have?
Try creating a new project and declaring an EN3TR. Let us know if you can create the module. As I said before, minor revision can be different if you set Electronic Keying to Compatible Module.
Just now I'm working offline in a project involving a PF7000 v10.2 and RSLogix only has support up to v10.1. I can open the module properties on the I/O tree but major and minor revision are greyed. The problem is I missing the datalinks information. Speaking with TechConnect people, they suggest me to re-create the module as v10.1 and next time update the database from the VFD (they don't have a webupdate for AOP PF7000 v10.2). This is not your case because there's no database involved.
Does the othe laptop on the field has RSLogix v20.01 or othe version? It's difficult to say but this problem can be related to the version of RSLogix. The usual advice is upgrade to v20.04.
Hi all I have a ControlLogix 1756-L71SP that i want to use for general PLC applications, not safety. I am running Studio5000 v33, i can't...
71
367
Hi, I have two quick questions: 1- Could I use 1756-IA16/A with TTL inputs? Sourcing (PNP)? Sinking (NPN)? Either one? 2- What does /A in the part...
161
Hi all, installed on chassis A17 an A/I from Allen-Bradley , problem is what ever I do , all channels are sticked on value 39.9 and cannot change...
145
Hi, Is it possible to for an RIO with Flex 5000 series module, e.g. 5094-AEN2TR, to communicate with an 1756-L72E processor.
93
