PowerFlex 525 Logic Status Word
James42005
Dec 2018
Waterloo, IA
35
Hello, I hoping someone can provide clarification on PF525 Status word, namely the .AtReference and .Active bits. I cannot find anything from Rockwell about conditions that set these bits in the drive.
AtReference is pretty obvious, but Im wondering what the threshold is? The +/- of the set speed that this bit is on?
Active, also should be pretty obvious, but still curious what exact condition(s) set this bit?
Any help would be appreciated.
.active is when the motor is receiving power from the vfd.
The sequence is .ready (start command) motor running, .active goes high. that is as long as the drive started.
Can’t comment on the reference tolerance. I don’t hardly use that bit much.
I don't know the +/- of AtReference, but not that when it drops below speed it def. removes that bid. So if you want to have up to speed, I'd use the bit to latch another saying you are atspeed even if it speeds up or slows down a little. If you need exact speed you are using the wrong drive or need some kind of encoder for feedback. (527 might be a better drive.)
I have an application using a Powerflex 525 for positioning. I really should be using a servo but the equipment is already in place. I have...
2,055
Hello everybody. I am a new poster to this forum, but have been using PLC.net to help me through issues for a long time now. So I have to say...
3,528
Good Afternoon , I have a project that I am beginning , that I will be using 3) PowerFlex 525's drives. I took notice of the StepLogic feature...
3,935
Fairly new to the drive so apologise for the layman terms. Textile machine uses PF525 VFDs to control motors. The speed of the drive is currently...
122
Hello, I'm hoping someone can help me with understanding how to set/change these data types. We recently swapped from Invertek to AB drives...
123
