Factory Talk ME "Trends"
rahilansari
Jul 2008
INDIA
103
Hi friends
I have configure the trend with 8 analog points and working fine but I want to log them for 60 days and same should be replaced by next 60 days i read some posts in this regard but no where find exactly where I should mention that I want to log the trend for 60 days. i have created a data log model also and refer it in the property->Pen setup. Could some one please help.
Also what should I do if I want to add 1 more analog point since the limit is 8.
All suggestions will be highly appreciated.
Rahil
The Data Log model will only create 1 file. It is a circular file that replaces the oldest data with new data. You cannot replace the file or create a new one.
The data log has a maximum number of entries (data points); you will need to adjust the update period (when it logs data) so that you get 60 days worth of data.
If you need more than 8 pens on a trend you will have to create a new trend object. It can (must) use the same data log.
Dear all, Facing some strange issue for last 2 weeks with factory talk view trends. Trends work great in real time and log the data as well. As...
17
8,786
Hi, I only need confirmation regarding the data log of Factory Talk View. I have 27 tags that I show on trends. I want to see trend of each tag...
3,799
hi.i dont have much experience about factory talk view. Recently factorytalkview scada stopped logging data. On my trends, i can't see charts...
4,291
I have recently added a trends in Factory talk 5.0 ME in one of the screens. But i have noticed that the trends plots the graph only when I open...
9,503
Hello, 1) How can I specify a variable for the eng. units for the table of a trend? 2) Is it possble to specify different scales for multiple...
16,078
