factory talk view trends data logging problem
pokajy
Mar 2008
Turkish
53
hi.i dont have much experience about factory talk view. Recently factorytalkview scada stopped logging data. On my trends, i can't see charts moving,there is nothing. only black screen.When I change trend settings to real time value, i can see charts online. but I can't see historical charts
Can you take a look at attached files and give me some idea please?
Strangely chart logging stopped at 08/04/2014 and it did not start to logging again. Logging stopped at midnight at 12:00AM.
At 4.jpg under File Management menu, previous setting was Daily (change at midnight).
Old files were under E:\DATALOG\Power_Ann
I deleted old files manually.. I thought it can start to logging again. but nothing changed.
under E:\DATALOG\Power_Ann there is no movement.🍑
Is there any other settings that I have to check?
Did the system reboot? And if it did, is there a startup macro run to start the datalog? Somewhere you need a "DataLogOn datalog_name" command.
Is there a button somewhere to shutdown the datalog?
no system did not reboot.it's server pc with several harddrives and power supplies. it has also ups. Strangely data logging stopped at midnight at 00:00.:unsure:
also there is not any button to start and stop to data logging.
There has to be a command line function or a macro programmed into FTView to turn on datalogging every start.
If you can connect to to the server with studio, you can issue the command from the command line in Studio.
135
Hi all, Attached below is an example of what is happening to our existing SCADA. It seems after patching some Rockwell Software that I thought...
334
The client has an application that when communication between the PLC and the Factory Talk VIEW supervisory fails, the object in the supervisory...
295
Hello all, I am looking for a way to have a user get logged out after an X amount of time because to default so that user privilages are no...
600
Hello everybody. I was wondering if there is a way in FTVIEW Studio to close ) view after x min without interaction . My issue is the following...
375
