Help on Message 248:47
Description of Error:
There is no access to the module via the online interface set with “Setting the PG/PC Interface“. For example, you can only address a module via the PROFIBUS interface if the programmable controller has access to a PROFIBUS network.
To Correct or Avoid Error:
Check whether the online interface is set correctly. Check the settings as required.
Check whether the station in which the module is located is configured correctly. Change the configuration if necessary.
You need to setup your comms interface.I have installed Simatic Manager. Then I have choosen appropriate PLC type ( CPU315-2DP). I created simple program. When I try to download this program to PLC I receive this error:
I have installed Simatic Manager without any problems. The version 5.3. The PLC is in Stop mode when I am downloading. Could anybody help me?
2 optiions.I am using cable for MPI network. Adapter is RS485. Could you tell me where is 'Set Pg' option in Simatic Manager?
