Communication between S7-300 (V5.5 SP3) and S7-300(TIA portal)
Apache
Dec 2014
Finland
I have a project where I must build communication between S7-300 (TIA) and S7-300(V5.5 SP3).
I found a document(https://support.industry.siemens.com/cs/de/en/view/92269951) that includes the instructions for doing the communication between S7-1200 (TIA) and S7-300(V5.5 SP3).
I guess this works also with S7-300 (TIA) and S7-300(V5.5 SP3)??
S7-300(V5.5 SP3) is old, maybe from 2003. There i use CP-343 module. New CPU is IM 151-8 PN/DP.
You need unspecified connection and then you can use put/get blocks on master side.
Im151-8 can be master. S300 with lean Card only slave
CP343-1 Lean-model = slave only
CP343-1 = Master and slave
CPU 3xx PN/DP (build in profinet) =Master and Slave
CPU 151-8 = Master and Slave
hi how can i Communication between Siemens S7-300 and Vijeo Citect 7.2 with Ethernet tcp/ip ? please help me!🤞🏻🤞🏻
1,793
hello dear we have a problem with communicate with delta dop hmi and siemens s7-300 cpu . we use ISO ON TCP connection and AG-SEND and AG-RECV...
3,494
I want to realize the communication S7 and pc by cable profibus or mpi I want to know the steps to that allows me to do it
1,267
Communication Stop between S7-300 DP port & DCS We are having 6ES7313-6CF03-0AB0 (SIMATIC S7-300, PROCESSOR, 313C-2DP) at site. Its DP port is...
1,857
Hello, i need some help!! i connected both via rs-485 by lan cable. HMI PLC RJ-45 Mini Din 8 pin pin4 A <---> pin1 A pin5...
2,014
