In modicon quantum consists of main rack in which the cpu 140cpu43412A is located
Mohammed zaid
Jan 2023
Yemen
17
Main rack contained power supply 140cps52400 and 140cpu43412A and RIO HEAD 140CRP93100 in addition to another I/o cards . Another remote rack containe power supply 140 cps51100 and RIO DROP(140CRA93100) in addition to another i/o cards digital and analog.
As we know RIO HEAD and RIO DROP connected to each other using coaxial table.
The problem occurs suddenly no power on the i/o cards of remote rack and error ERROR A appeared on the RIO HEAD OF THE MAIN RACK.
For the first time i think the power supply in remote rack damage and shut off all related cards in that rack but the power supply tell me pwr ok as on it's display. Then i tightin the coaxial cable on the RIO DROP and the power back to the i/o cards, i can't understand why when tighten the coaxial cabe the power pack to i/o cards.
What is the type of signal transmitted between RIO H. and RIO D i dont think such signal employed for powering remote I/O cards, but why when retightin the coaxial cable the remote i/o cards turnning on.
It could very well be that the connector has come loose from the cable or was improperly crimped to begin with. I suggest verifying your network components and other practices against the manual (https://www.mroelectric.com/static/application/product/pdfs/MA-0185-100.pdf).
People take shortcuts with these networks by treating them as one would a cable TV network. If you've any doubt, get new connectors, the proper crimping tool, and redo the connections/network per the manual.
Good luck
I've had an issue before with a quantum PSU failing but still showing power ok light. I would change the PSU before messing around with anything else.
Similar thing occurs with me but when tightin the drop cable to RIO drop all i/o cards turn on again and that thing which i can't understand.
Yes PSU is the responsible for suppling all cards beside it, but why this happen for me.
Hello All, Was hoping I could get a little help with Modicon ladder logic. This is the first time I have seen Modicon logic and currently trying...
261
Hi There, I have a Modicon Quantum PLC, there is a alarm on display "noConfig" its happened after power failure, I have gone through manuals...
652
When i read the specification of 140CPU43412A i observe that as remembered in specification 1. Local i/o : Maximum i/p and o/p words are 64 in...
496
System Details: We use hot redundant Modicon Quantum PLC with dual redundant communication having Remote IO racks (using CRP + CRA cards and...
774
We are now planning to upgrade from Quantum 140CPU11303 to Modicon M580. The software protect was written by Proworx NxT (.DCF). Is it possible...
1,002
